My G35 headset is not activating the surround sound when I turn on the G35 software... It keeps telling me to unplug and replug my headset. I've tried numerous times but it still doesn't work.
SOURCE: I'am having difficulties trying to pair my bluethooth headset with my cellphone
maybe you have problems with the battery of the device.. have you fully charged it?
how old is that headset? and what kind of cellphone do you have?
SOURCE: Samsung WEP200 Headset
Hello Sir,
You must be frustrated by this problem. It should be easy to solve. All units transmitting on an open channel have a unique identifier. This is the Pass Key.
1.) Check under the transmitter and there should be some numbers. The one above the bar code is usually the passkey, but it could be another on the label so write them all down.
2.) Click on the Blue icon next to your time display in the System Tray.
3.) Double Click your bluetooth headset and when prompted for the passkey enter the first number you wrote down. If that does't work try the others. One of them is your passkey.
If you need further assistance comment back to me and I'll be glad to help.
Kind Regards,
Worldvet
SOURCE: No audio from computer to Motorola S805 Headset
I posted this problem a long time ago. I updated to Windows 7 and my headphones immediately worked flawlessly!!
SOURCE: My blackberry curve recognizes the
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
