Just that. you turn it on, it smells funny, like partially burned natural gas, and doesn't heat to cooking temps. it got warm, but not hot enough to cook. and it doesn't show an error code.
Oven temp. 25 to 75 degrees low depending on setting and will not cook meat at setting.Oven temp. 25 to 75 degrees low depending on setting and will not cook meat at setting.
AnonymousDec 28, 2007
The oven won't consistanly heat. Sometines, I have to turn the broiler on then quick switch to bake and then it will work.The oven will work one day but not the next.Sometimes it heats up but doesn't stay hot.The oven won't consistanly heat. Sometines, I have to turn the broiler on then quick switch to bake and then it will work.The oven will work one day but not the next.Sometimes it heats up but doesn't stay hot.
AnonymousFeb 15, 2008
Oven will not reach proper temperature when turned onOven will not reach proper temperature when turned on
AnonymousMar 01, 2008
after oven cleaning, it doesn't bake anymore. temperature quickly goes to 115* and stops. everything else is functioning OKafter oven cleaning, it doesn't bake anymore. temperature quickly goes to 115* and stops. everything else is functioning OK
3 weeks old. First time it's had this problem. Model 8890, small oven on top, convection oven on bottom, Freestanding model Top oven works, bottom oven will not light.
you can run it at 350 for like a half hour or so and you'll smell a funny smell from the metal heating up,when i replace an ignitor or an element i run it for like 10 minutes just to burn off the smell of the metal.i'm sure the factory already had that fired up to check it but i would start it and burn anything off of it that might be in there before i cooked anything,it can't hurt it.good luck with your new machine.
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat -- defective selector switch -- defective gas safety valve -- defective gas valve coils
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
A good pre-heated pizza stone will help cook the crust better when the pizza is placed right on the stone. As for the cheese burning, check the actual temp. of the oven with a good thermometer.
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
oven won't heat at all.
My Oven is the same way one day it will work the other it will not.
It will heat for a couple of minutes then not at all..Its driving me crazy...
oven will not heat up
i bought a new ignitor and the oven still will not heat up
