The err message has nothing th do with theft lock. More than likely the laser assembly is bad. You are probably better off replacing the deck with an aftermarket one.
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
I've had this happen once before..CDR's are a little bigger than regular cd's.Sometimes they wont let go at all..You either can undo the battery and then reconnect then it usually automatically ejects or you'll have to manually do it or you can pull the fuse and then put it back in and the same proceedure..
if you are using good,new,cd,r and no accept try to do this in a room with no light put in operacion the cd player see what happens......if the same time to change for a newone or sendit to repair shop
