My subwoofer works great but thats the only sound i have. i can't get any sound from either speaker but when i plug headphones into the remote they work fine. What do i do to the speakers to get some sound other than just bass out of the woofer?
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
This isn't uncommon among logitech speakers.
can you give me the m/n, p/n, and pid of your speakers? this will help determine whether this is a hardware error or speaker defect.
I need one driver for instalation of my logitech thx ?
I contacted logitech and they said the speakers are definitely broken. Obviously, it's a hardware issue as physically changing the hardware fixes it. I spoke with someone who actually knows what they are talking about and they informed me that this is caused bu a malfunctioning, usually broken voice wire (inside the speaker) the only way to fix this is to replace the speakers. on the bright side, it's only $20 each. Here is the new speaker:
Parts-Express.com: Tang Band W3-926SD 3" Driver | full range driver 3" woofer extended range driver tang band tb speakers tangband-41108
Hai. First you have to download REALTEK HD Sound Effect Manager, and to install it. Then it properly work. Or try to some Sound Effect Manager. Ok
I'm having a similar issue. No matter the input to it, there's no sound from the speakers, only the sub. By chance I found out that if I press lightly on the speaker itself (with the cover removed) I can hear from them. Aside from this, no sound at all, not just quiet. Is it possible the speakers got blown? I've only ever seen the black film tear when that happened, not both speakers becoming perfectly disconnected at the center.
