I have a TomTom GO 920. Used it in Europe and was fantastic. Home in Australia now and cannot switch back to Australia map. TT reads "You cannot use this map on this device: Australia 4".
I have used the Australia map in the past and got it briefly the other day before i foolishly changed back to Europe maps to find something. Now i get the above error. TT support have not got back to me and i need to use my TT for an Austrlian holiday nevermind the fact i live there as well! Any help would be appreciated.
SOURCE: tomtom 1 (new edition) map of europe
I think you'll find that you can download it from tomtom home, with full technical help online & on the phone.
I dont advise COPYING it from a friend as you will get a symbol appear on the screen with a tomtom SD card with a large red cross through it, indicating that the tomtom knows its not a genuine copy.
SOURCE: changing maps already installed
Hi, Answers to your 2 questions 1 and 2 . ...... 1/ go into PREFERENCES , hit right arow key till you see MANAGE MAPS , Tap that MAP icon and in there will be all the maps you have on the SD card. Select the map you require by tapping the screen. ............................................. 2/ YES , backup the SD card to your PC first. ( you should save everything on the card as it is ) Then delete the Europe map off the SD card and replace it with the USA map . You will need the authorisation code for the USA map in order to activate it. When you return you can swap the maps back again.
SOURCE: Current time on TomTom 920
Turn on your tt. On the map screen tap the screen then tap the wrench (change preferances. Tap the forward arrow until you come to set time. Hope this helps.
SOURCE: tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
