I get standing water on the bottom of my Bosch dishwasher SHX33A. When I run the dishwasher at the end of the cycle there is no water, than later the water shows up sometimes up to 2 to 3" in the bottom. When I turned the water off under the sink the base stays dry. It is not leaking from the top arm and when I close the door sometimes it starts to pump the water out.I've checked the elbows under the sink and there fine, don't know what else to do please let me know what this could be Thanks Jim
SOURCE: Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
SOURCE: we have a bosch classixx free standing dishwasher
Hello Becky,
The most likely causes are a failed drain pump motor (or capacitor) or a jammed/broken pump impeller. There is a very simply simple test on classixx models which which help you to determine the cause, or where to look next.
1. Turn the wash cycle selector to any wash cycle so the "ON" light is illuminated, but do not press the START/STOP button.
2. Open the door and pull the lower basket out.
3. Locate the 'float', lift it up fully and keep it held up.
(The float is a dome/mushroom shaped protrusion in the base of the washer just to the left of the drain and partially hidden by the spray arm)
When you lift the float, the drain pump should run instantly and the water should drain from the washer. If you can hear a low hum from the pump motor in the base of the washer, but the water doesn't drain, then it's likely that the pump impeller is jammed or it may have broken away from the spindle. If this is the case, try repeatedly lifting and dropping the float fairly rapidly. Repeated stop/start signals to the pump motor can sometimes free a stuck impeller.
If you cannot hear any noise from the base of the washer when you lift the float, then the drain pump motor or the motor capacitor may have failed. A failed capacitor is often accompanied by a buzzing noise. Further testing will be required to determine the exact cause of the fault.
Please try the simple test above and then post back with the results for further assistance.
Hope this helps.
Regards,
BElectric
SOURCE: My Bosch shu3307uc pumps out all the water at the
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
Testimonial: "The fix was easy and exactly as described, and works perfectly! Thank you very much! If you need any car advice, look me up, I will be glad to help! Bob"
