Please RUN the software calibration for eady diagnostic and fix it. God bless you
However follow this steps and fix it. God bless you
Probable Cause
1. A failure in the upper PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the input voltage to the upper PCA to be too low.
Corrective Action
External causes may make the error appear intermittently.
Description
Errors 30 through 33 all indicate the loss of communications or erratic communications between
the microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures for
all of the are essentially the same. Error 30 is defined as upper PCA not receiving from lower
PCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lower
PCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCA
Possible Causes
1. An upper PCA to lower PCA interconnect cable is bad.
2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.
3. A 5.17 EFX equipped with version 1.01 upper and lower software.
4. A 5.17 with mismatched upper and lower software.
5. A defective lower PCA.
6. A defective upper PCA.
Possible Remedies
1. Substitute a know good interconnect cable between the upper and lower PCAs to determine
if the interconnect cable is defective.
2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upper
PCA connector.
3. Replace the 5.17 upper and lower software with the most current software versions.
4. If only one of the upper or lower software is version 1.01, replace the version 1.01 software
with the most current version of software.
5. Substitute a known good lower PCA to determine if the lower PCA is defective.
6. Substitute a known good upper PCA determine if the upper PCAs defective.
