Arctic Air SCW120 Wine Cooler Logo
J
Jannie Posted on Nov 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Digital temp control does not display when on
I have the Artic Air 120 wine cooler and the digital temperature control and display do not light up when it is plugged in. It is 4 years old. And it does not cool. Light switch does go on and off. Please help Thanks
richie46
Level 3:
Top Expert:
  • Arctic Air Master 12,962 Answers
  • Posted on Nov 23, 2013
richie46
Arctic Air Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941777
Points
58151
Either the compressor is shot or the circuits controlling its operation are no good. Since the display does not light up I am sure it is a controller problem and the module needs replacement.
2 Related Answers
Anonymous
  • 135 Answers
  • Posted on Jan 25, 2011
SOURCE: I have an Artic Air r22cw refrigerator (less than
i am not sure that can help u. i think u deforst problem.
http://www.youtube.com/watch?v=TnRKj7_BtNw&feature=related
Anonymous
  • 3773 Answers
  • Posted on Sep 19, 2011
SOURCE: artic air refrigerator not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
1helpful
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
2answers
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
2helpful
My refrigerator keeps going into freeze mode instead of the temperature that i programmed into it.
if unit has a thermistat you need a thermistat if it has a digital diplay you need a control and thermistor. these are what controls the temps when they get to desired temp
The temp. sensor displays the wrong temp.
Dear Sir/Madaam,
The 6SBAR-BS-G does not have a digital temperature display. Could you provide your correct model number? The 6SBARE-BS-G does have a digital display and has two temperature sensors.
One is used for control and the other is used for display. The are connected to the back of the display board by small white molex connectors. The smallest is for (two pin) is for the control and the three pin (although only two of the pins are used) is for the display.
The unit does not have to be removed for it's installed location to change the thermsitor, (temperature sensor), but you will want the power off when you swap it out.
You can order a new sensor from a few sites on line but the best thing to do is call the factory direct at 800-223-3900. The part number for the display thermsitor is 42246463 (the control thermsitor is 42246462). If your unit is more than a year old you may wish to replace both sensors while you are doing the work. If you are doing the work yourself, ask the customer service technician if he/she would email you the service manual as well.
Let me know if you need any further assistance - Subdriver
2helpful
2answers
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Top Arctic Air Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you an Arctic Air Refrigerator Expert? Answer questions, earn points and help others
