1.paper is placed in the top tray 2. hit the print or scan button. 3. the paper is drawn halfway into the machine, and hangs up on the left side although the right side of the paper moves an inch or more before the machine indicates paper jam
SOURCE: Paper pull only fron the right side
You may have a jam insude the unit. Open it up as if you are replacing cartridge, check everywhere for a tiny paper jam, with a torch, near roller, carriage etc. good luck xxx lilacgerry
SOURCE: Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
SOURCE: Lexmark T632 top tray is ejected when empty
Set tray 2 to be default tray. When this is empty, the printer moves to tray 3, and then on to tray 1.
SOURCE: Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
