Hitachi DZ-HS300A DVD Camcorder Logo
Posted on May 06, 2009
Cannot download PIXELA ImageMixer 3 SE from my cd, it is scratched and the website doesn't allow me to dowload it can anyone help?
  • 1 more comment
  • Anonymous May 17, 2009
    I need the cd
  • Anonymous May 22, 2009
    thers just a bunch of updaters .. i lost my cd ..i cant bealive there is no full version of IM3 i need it to use the hitachi drivers
  • ckkim May 24, 2009
    terrible imagemixer...i bought CANNON FS100A with imagemixer CD, however, i could not get approval from internet...i tried many times...useless...not convenient for customers...
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8981
Points
10
Canon makes all kinds of promises about what you can do with their wondrous Pixela software, most of which is untrue.
Like most bundled software, it's really bad. It says you can burn directly to a DVD. You can't. It conveniently forgets to inform you that if you record in MXP 24mbps mode, the file will be downconverted to 18mbps. It says it can write to a DVD-R or DVD-RW from the computer. It will render for a long time (10 minutes for a 6sec clip) then attempt to write to the DVD, THEN tell you that the WRITE FAILED without explaining why.
Bottom line, this is terrible editing and logging software.
How can I download the software for ImageMixer 3SE? I have misplaced the disc for this software and need it for my Cannon camera Vixia HFR100
You can download some software for the Vixia HF R100 here: https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-high-definition-camcorders/vixia-hf-r100 . However, ImageMixer 3 SE is third-party software that is only available on the driver disc that came with the camera. Some companies will send you a replacement disc for a small fee. You'll need to contact Canon support, https://www.usa.canon.com/internet/portal/us/home/support/ , to ask if they have discs available.
ImageMixer 3 SE is available here: http://www.pixela.co.jp/oem/canon/e/imagemixer3_se_canon/ . However, this is only for updating the software on a computer that already has the program installed.
I hope this helps.
Pixela imagemixer 3 se download
Codigo para control remoto PIXELA, LED No Smart
1helpful
Unable to transfer videos from Canon FS300 to my pc or network drive
MOI is a computer file format used primarily to represent information. MOI files are associated with MOD or TOD files whose content they represent. The Pixela ImageMixer Video Editing Software should allow you to save your videos to your hard drive. But you may need to install the latest version of Quicktime Player (free) to view the the .mov files as an alternative to the ImageMixer program's viewer. Source(s): http://www.apple.com/quicktime/download/
I have mislaid my version of image mixer for sony camcorder DCR-DVD100E. Is it possible to dowload from site
i'm really sorry the supplied imagemixer software was designed and created by a 3rd party software company commissioned by sony called pixela, this software is not available for download from our website (due to copyright conecrns): http://www.sonydigitallink.com/dime/camcorders/sd/dcc/dcc.aspxsite=odw_en_GB&m=DCR-DVD100E
and its not available form the pixela site either (all they have are updates w/c requires a full installation of the software to make it work): http://support.dimaging.sony.co.jp/www/disoft/int/pixela/imx/dl/index.html
...anyways if your computer is using a windows vista or 7 OS, this software is useless and compatible (so there's no point in purchasing it). but if it's windows xp and you would really like to purchase the software try to check w/pixela (1-800-458-4029) if you can purchase a replacement software from them (make sure you tell them it's a dcr-dvd100E-european model).
...or other options for importing files check this: http://www.kb.sony.com/selfservice/microsites/search.docmd=displayKC&docType=kc&externalId=eSupportINFO64ENR1&sliceId=&docTypeID=DT_INFOITEM_1_1&dialogID=157560680&stateId=1200%20157576019
hope this helps. thanks:)
1helpful
Thumbnails not loading in Imagemixer library. File names
I have the HG20 that had the same problem. I called Canon support (very nice) turned out that I was using the USB port on the front of the computer. Disconnected and used the USB port on the back of the computer (motherboard) now everything is working fine. Apparently there is a USB hub problem when using the front USB ports. Hope this helps.
1helpful
I lost my image mixer software for my canon fs100 anybody can help me out?''
Download from here :
www.10001downloads.com/s/Pixela-ImageMixer(TM)-3-SE-for-canon-FS100.html
Or go and select ur OS and get Image Mixer from here :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=2547&modelid=16185
Sony driver update
You can down load the driver for vista of sony DCR- DVD 100E/DVD 200E from the following links
This chart provides compatibility information for software that ships with Sony digital cameras and camcorders.
Note: Not all software applies to all models. If uncertain, please refer to your product manual to determine which software came with your model.
Software Compatible Additional Comments Movie Shaker™ software Ver 3.1 for MICROMV camcorders No N/A Nero® Express 6 No N/A Pixela ImageMixer™ for HDD Camcorder No Please update to Picture Motion Browser Ver. 2.0.11
Note: This software is not applicable to all models. Pixela ImageMixer Ver 1.0 No N/A Pixela ImageMixer Ver 1.5 No N/A Picture Motion Browser Ver 1.1 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.0.01 – 2.0.06 Yes Some behavior may be different from that of the previous Windows XP operating system environment. *3
Please install the update program for Windows Vista. Picture Motion Browser Ver 2.1.00 – 2.1.01 Yes N/A Pixela Picture Package™ software Ver. 1.0 – 1.7 No Please update to Picture Motion Browser Ver. 2.0.13
Note: This software is not applicable to all models. *2 Pixela Picture Package™ software Ver. 1.8 No Please update to Picture Motion Browser Ver. 2.0.12
    *1 It is not possible to save RAW files in the SRF format with the Image Data Converter SR software.
    *2 It is not possible to create a Video CD using Picture Motion Browser.
    *3 Examples of behavior variances:
    Display -
    • The Picture Motion Browser short-cut icon may become a Windows-standard icon.
    • The tooltip information window may not be transparent.
    • images may not be displayed properly in the browser window while playing back movies.
    • Some images, character, and icons may not be displayed properly.
    Sound -
    • The volume control bar in the browser may not be operational when playing back movies.
    • While playing back movies the sound may not be output.
    Other -
    • Some folders, such as public folders, cannot be registered as Viewed folders.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
11helpful
6answers
SOFTWARE FOR HITACHI CAMCORDER
I have the disk for the Hitachi DZ-HS500E and will create an ISO of it and YouSendIt to you if you want.
1helpful
I have no sound on my sony handycam
Sony got back to me with the answer, so I will post it here for future reference.
If there is no audio when USB streaming with PIXELA ImageMixer version 1.5 software on the Microsoft Windows XP operating system, change the USB capture device setting for sound to USB Audio Device. In the Image Mixer Tool settings, confirm the USB Capture Device settings are set for an available USB Audio Device. This setting is not defaulted to the USB streaming mode.
This would be the icon of an open end wrench in the top right hand corner of the capture environment screen.
Follow this procedure to change the USB capture device setting for sound in the Pixela ImageMixer 1.5 software.
1. In the ImageMixer window, click the USB Device Capture icon.
2. Click the Preferences icon.
3. In the Capturing/Recording Preferences window, in the USB Capture Device Setting section, click the down arrow to select the desired sound device.
4. Click the OK button.
For any request for processing or editing assistance you may visit the PIXELA help file. You may also contact them at the following website:
www.imagemixer.com
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
