Dell Inspiron B130 Notebook Logo
Posted on Oct 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop battery won't charge
I have one Inspiron B130, I bought it used and with the advise that the AC adapter was bad, so I bought an ac adapter new and the laptop works perfect but the battery doesn't take charge. I bought a new battery but with this one I'm having the same problem, it won't take any charge.
  • hgasval Oct 09, 2007
    When I connect the laptop to the wall outlet with the laptop turned off, the led that show if the battery is charged or discharged steady turn on green but later change to flashing yellow. I don't know if this is a useful tip to know what is the problem.
  • Anonymous Mar 30, 2014
    I bought a new battery for my dell inspirion b130 notebook, and it still wont hold charge, without the powercord and adapter.
Gareth Cockram
Level 3:
  • Master 661 Answers
  • Posted on Oct 09, 2007
Gareth Cockram
Master
Level 3:
Answers
661
Questions
Helped
316096
Points
1733
Possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
2answers
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
The light for the charger turns on but the computer won't turn on
Does the battery charge light come on? If not, then you either have a bad AC adapter or the motherboard is defective.
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
1helpful
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
1helpful
My Inspiron B130 will not charge,even with a new battery. I plug in the power cord, will not charge still. No power light, nothing
just had the same problem- the socket where you plug in the adapter had shorted out-needed to be resodered-no big~100$
BUT my ac adapter was bad as well- may have caused the short (they are cheap on ebay)
Toshiba M15-S405 Battery Won't Charge
hello,by anoteher charger,you`r capacitor on charger is poor.best solution for you is to by a new charger,that is 100
Pc keeps blowing ac adapters
hi!
the motherboard on your laptop is shorted to the ground. It happens when you unplug the ac adapter cord from the back of the computer a lot. Call Dell's reknowned tech support and ask for the motherboard to be replaced.
Karlox
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
