I have Kenmore 253 refrig that the door will not close and there is a 1/8 gap on the side opposite the hindge. How do the door adjustments work?
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer
door. Stand "inside" the open door and place your foot at the right
bottom corner (looking from the inside). Place your hand in the top
right corner and pull it very slightly toward you. Do this in small
amounts until the gap closes making sure you don't open one at the
bottom.
An alternate method is to warm the gapped section of
the door seal with a hair dryer to soften the rubber enough to allow
the magnet within the rubber to pull the seal gap closed. This has
worked for me numerous times by making small adjustments at a time.
Good Luck
