Computers & Internet Logo
A
Anonymous Posted on Oct 06, 2017
Wireless radio off
When I plug my MIFI 2372 to the PC it works, (It shows a brief message informing "Radio OFF". If I disconnect to MIFI from the PC When I try to use the Wireless it does not work because the wireless radio off (I cannot see the MIFI Wireless SID because the wireless radio on the MIFI is off. So, how do I turn ON the wireless radio of the MIFI 2372?
5 Related Answers
Anonymous
  • 279 Answers
  • Posted on Aug 29, 2007
SOURCE: 802.11g Network Adapter Radio Control Switch
It's not a physical switch, and they really should put more thought into the error messages they write. To "flip" the "switch" you hold down your function key and hit F2 (you'll notice a little symbol on the F2 button - that's the "radio switch"). After that, just right click on your wireless connection and choose repair.
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Dec 26, 2007
SOURCE: wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Anonymous
  • 142 Answers
  • Posted on Feb 19, 2008
SOURCE: wireless radio adapter
if ur sure that that it is the fn and f2 that u have to press simultaneously to turn on wireless capabilty. Make sure u press it long enough
Right click on wireless network connection item in ur system bar and goto view available wireless connection and check what message is displayed there
If it still says that " No wireless network were found , make sure wireless switch is on "
Contact COMPAQ
If ur not sure whether it FN F2 , then try to FN & F5 or FN & F2
Anonymous
  • 275 Answers
  • Posted on Nov 05, 2008
SOURCE: wireless adapter radio
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Anonymous
  • Posted on Nov 29, 2008
SOURCE: wireless radio control problem
Try going into the Device Manager and making sure the Wireless Adapter is enabled. Click Start > Control Panel > System. Click the Hardware tab then click the Device Manager button. Now click the Plus [+] next to Network adapters then double-click the wireless adapter which is probably the Intel(R) PRO/Wireless 2915ABG Network Connection which will open the Properties dialog. Ensure the Device status reads, "This device is working properly" and Device usage shows "Use this device (enable)." If either the Device status or Device usage shows anything other than what is shown above, first try to change the Device usage, which should change the Device status. Now try again to use your wireless adapter. You might need to press Fn + F5 to turn the device on.
Wifi will not turn on
As simplistic as this may sound, the only power source for this device is the battery. Therefore, change the battery and power up.
Mifi 2372The blue wifi light is blinking and the power light is a solid violet. I cannot obtain internet access..what to do?
Have you check to see if the apn settings of your srervice provider are correct configured in the device user interface? You can also contact your service provider and request them to provide you the correct settings wich will allow you to connect. Please let me know if you came rite? If not, try to obtain the settings and I shall provide you the steps to configure your device correctly.
Connect mifi
Open internet option's or "create homegroup" option on your pc and enable your pc to become an access point. Doing so will allow the pc to share the wifi with any compatible device. The handset cannot find the IP due to a firewall so turning those off manually would also work but do so only as a last resort.
5helpful
2answers
Verizon MiFi 2200 blinks red then shuts itself off when I plug it in. I know red blinking means critically low, but it won't charge and I have left it plugged in for hours. I held the reset button down for...
Mine did this, I went to Best Buy where I bought it. They didn't really seem to know, said it could be the power cord to the wall, but they didn't sell them. But they could set me up with an upgrade (and new 2 year contract that I didn't want). Anyway, I went to Radio Shack and showed them my MiFi 2200 and they had the new wall charger power cord there. Works now, problem solved for $25 instead of a new 2 year contract.
I purchased a mifi 2372 from att to connect to a ps3 for my son who lives in an area of limited internet service. I've called tech support at att and sony to see if they can help since everything I've...
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
1helpful
Just got a mifi 2372 and I can't install it. As soon as I plug it into my computer the wifi light goes off and the computer can't detect it. Can u help
The MiFi is not meant to be cabled to your computer while in use. The manual says the cable is only for software updates and charging it when not in use. Just turn it on without the cable and the computer should detect it. Be aware that it takes a long time to boot up (maybe a minute or so) and that even when the little blue light comes on at the side of the device it can still be another 10-15 seconds before the computer will see it.
2answers
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
7helpful
NOT READY error message
Try this:
On the fuse panel in the dash is a black jumer not described in the manual or panel cover. It's a quick power disconnect for radio and clock.
Pull it, wait for a brief time, replace it in the original orientation.
Wireless radio switch
connection.
Top Novatel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
