Waffle iron (Krups 654-75) died, no light, no heat. I have continuity on both heating elements but there is a little device which looks like a diode but may be a thermostat which has no continuity. It is inline with the power cord and has 240 C printed on it. Should I have continuity on this and could replacing it solve the problem? If so where could I find one?Thanks
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
I think you're right, I looked up thermal fuses after reading your post and found one just like the one in there. Online it was just over a buck a piece so that should be cheaper than replacing the whole unit. Thanks.
Indicator light illuminates, but no heat.
