1 have a 1995 Honda v-6. I had to replace the battery and now the car radio does not work. I had purchase the car used and did not get the audio code and the dealer is now long gone. Is there a way to retrieve my radio serial number without removing the radio. Please help because Honda is charging $100 to have them remove it for me.
Probably after the fact but.. You can get the instructions to remove the radio yourself. You can Google around online or get a Hayes or Chilton manual. Some libraries even have these for older vehicles or you could buy one for less than $20. I've done it. Also, check out the following for when you have your serial number.
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
Hi there. First thing to do is contact the original selling dealer. They are sure to have a record of the radio code on their records. Failing that, the original selling Dealer might be able to contact the original owner on your behalf and obtain the code that way. Unfortunately, you do need to remove the radio to be able to read the radio code, but $100 seems a lot to that! Best regards. Scottech.
Ring honda dealer up and give dem ur vin number formally none as ur chassis number and reg number they should give it to u over the phone
