SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
SOURCE: How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
SOURCE: Fridge makes loud noise every ~10 minutesq
Does it have a ice machine it it? If yes, that means it is very normal mine does it thats what happens, if no... Then go get a new one, and bring it back. You may have a loose screw
SOURCE: Jenn air French door refrigerator model JFC2087HRS
The compressor is bad....
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
