Did you verify that the relay terminals have the appropriate signals to them?
ECM fuse B (20-amp) should provide power at all times to the orange wire of the fuel pump relay. The relay coil receives ground via the black wire, and relay coil gets power from the dark green/white wire. When the relay is closed, you should have battery power on the gray wire.
The relay trigger wire should have power from the dark green/white wire in terminal 1 of the Vehicle Control Module (VCM) connector for the first couple of seconds after they key is turned to run (to prime the system) and when the truck is running. Checking for all the appropriate signals at the relay is where I would start. That is after I checked for diagnostic codes.
Believe the fuel relay is the middle relay out of the three in the left rear of the glove box. Last thing is to hot wire the fuel pump if you can not get it scanned, see if the pump is bad unless your going to have a shop work on changing the fuel pump.
Good luck and hope this helps. keep me posted.
Thanks all. it was 2 things in the end a grounding issue and the oil pressure switch.
check oil pressure switch. Will automatically turn off fuel pump, when ther is no oil pressure. Hope this helps.
