The keyless entry works fine the car starts fine without sticking the key in but the dash keeps displaying low key battery, even after changing the battery. Any ideas why this is happening and also some times the car does not automatically unlock on the driver side when i attempt to open the door.
SOURCE: Acura RL 2005 Smart Key problem
Does the car lock open with the switch on the door? If it does not, it is not the key.
SOURCE: kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
SOURCE: Driver side door will not unlock with key or with keyless entry
frist check your wires and make shore you have power. if your lock still dont work its the power lock motor in that door ok . have a nice day
SOURCE: 2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
