I am trying to use the HDMI port of my LCT2785TA with a Panasonic DMR-EZ47V. The TV shows no signal, not supported, with 480i or 480p in the top left corner. I have tried the DMR with another TV and the HDMI port works fine. Is this TV HDCP compatible? Is the HDMI port compliant with current specs? Where can I go to find out if these two items are compatible. How can resolve this issue? I have tried 2 DMR's, , 2 different HMDI cables. The first cable has gold connectors , 19 pin , latest technology. The second cable had a bandwidth of 5 gig. I could not find a cable labeled ver. 1.1. I have connected the DMR and HDMI cable to another flat panel TV with no problems. I have contacted Akia tech support not getting anywhere. They have stated that the HDMI port would only work with ver, 1.1 or 1.2 cable. I purchased the low bandwidth cable with no success. Akai now says that the HDMI port will accept the signal because it is coming from an HDCP device. Help Help Help ! Thanks!
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
