Apple iPod MA446LL/A MP3 Player Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an apple Nano(2G). Running software 3.1.1 Itunes is 8.1. When I plug it in yy computer and device manager recognizes the device but itunes does not recognize the IPOD when i plug it in.
Steve Brown
Level 3:
President:
  • Apple Master 688 Answers
  • Posted on May 13, 2009
Steve Brown
Apple Master
Level 3:
President:
Answers
688
Questions
Helped
394074
Points
2264
Here is a trick I have tried and it worked.
in My Computer Right Click your Ipod device and explore the memory.
in the device software choose a file and right click and open with iTunes.
if your itunes is running it should try and open in itunes.
If it doesn;t work,
Try another USB port preferrably a USB 2.0 port.
Good Luck
When i plug my iphone 4s into my pc with itunes running it doesnt recognize the phone, cable is good pc makes sound when i plug in
There are several methods you can try to fix this issue. One of them shows below.
How to Fix iTunes Not Recognizing iPhone in Windows 10 Before You Begin:
  • Make sure that you have the button Trust this computer on your iPhone when connecting to your PC.
  • Make sure that you have installed all Windows updates. This is to make sure that your computer device drivers are up to date.
  • Make sure your iPhone USB cable works well.
  • Make sure your iOS device is turned on.
  • Make sure you have the latest version of iTunes installed.
  • Now, the following solution may help you fix the iTunes issue if you found that your iTunes does not recognize iPhone in Windows 10 computer.
    Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
    Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
    Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
    Step 4. Then choose "Let me pick from a list of device drivers on my computer".
    Step 5. Click "Have Disk..." button.
    Step 6. Click "Browse".
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64.
    If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Then you need to install the driver for your Windows 10. After installing, unplug your iPhone, then reconnect it using USB cable. Open your iTunes and see if your iPhone can be detected or recognized by iTunes.
    For more details, check: How to Fix iTunes Not Recognizing iPhone in Windows 10
    Remove password ipod
    Depending on the model of your ipod it will differ
    iPod Classic password
    This works on an iPod 5 th gen
    Click start control panel scroll to folder options tick in the box to show hidden files and holders
    connect your Ipod to your computer
    Click start click click on you Ipod to open
    then go Ipod controls device there should be a folder saying locked
    Right click select rename to open or delete the folder your Ipod should now be open
    ipod touch password
    Launch the iTunes program on your computer and click "Help" on the main menu.
    Scroll down and click "Check for updates."
    Close iTunes.
    Connect your iPod to the computer using the supplied USB cable.
    Launch iTunes, which will display your iPod on the left panel.
    Right-click your iPod in the iTunes program and click "Eject."
    Close iTunes and detach your player from the computer to unlock it.
    http://www.youtube.com/watch?v=5uT8Utk5Tqg
    ipod iphone ipad password reset
    Unlock an iPod Model A1199
    Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
    When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
    In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
    Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
    Plug the iPod Nano's cable into the docking port on the iPod Nano.
    Plug the other end into the USB port on the computer to open iTunes.
    Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
    The iPod Nano's screen will be unlocked once it is ejected from your computer.
    Unlock
    Manual Guide download
    http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
    Unlock an iPod Nano Code
    With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
    In order to use the device's functions again, you need to enter the correct code.
    However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
    Plug the iPod USB cable into the bottom of your iPod Nano.
    Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
    Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
    Select your iPod Nano from the "Devices" list in the main iTunes window.
    Click on the "Sync" button to make a connection between your computer and your iPod Nano.
    Click on the "Eject" symbol once the syncing process is complete.
    Remove your iPod Nano from the USB cable.
    The iPod's lock code will now be reset and you will be able to access all features again.
    Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
    Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    iPod Support
    http://www.apple.com/support/ipod/
    A1199 unlock code
    I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
    • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
    • iTunes online? - Confirm that iTunes has been downloaded and installed.
    • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
    • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
    • AMDS - Re-verify that AMDS is running and installed.
    • iTunes usage - Remove and reinstall iTunes.
    hope this helps
    2nd gen nano not synching
    DId you install Itunes?
    Without Itunes the computer does not recognize the Ipod...
    1helpful
    I plug my ipod nano 2gb to my windows vista computer and nothing happens, I have downloaded and installed itunes. I dont have the internet at home so i download everything at my in-laws. it does say it's...
    If you connected your nano before you installed itunes your computer saw it as a storage device already anditunes will not see it. You must uninstall the nano from your computer by going to the hardware tab on the system properties window. click device manager on that tab and all hardware installed on your computer will be listed there. Right click on the nano and chose the uninstall option on the box that comes up. Do this with the nano not connected. After you uninstall it start itunes then connect it to the computer. Itunes will then recognize it and take you through the set up.
    366helpful
    21answers
    Ipod not recognized by computer or itunes
    I struggled with this issue for a while and finally found a post that helped me. Hold menu and the center buttons until the iPod turns off. Then, immediately hold the left and center buttons to pull up the iPod diagnostic menu. Scroll down to the option "Reset" and select it. My iPod was finally recognized by iTunes. Good luck :)
    My ipod nano 2g cant recognize my computer
    If your iPod fails to hold a charge and it's more than a year old, you may need a new battery - http://www.apple.com/support/ipod/servic...
    Hope this helps.
    TWEAK A/V LAB
    Top Apple Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    ZJ Limited
    ZJ Limited
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
