Nokia 1600 Cellular Phone Logo
Abhijit bhattacharya Posted on May 06, 2009
What is"no.screening" under message in my nokia menu?
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
721
Points
11
Haiiiiiiiiiiiiiiiiiii me heelp you contekt no=9996704380
How to change nokia c7 mms settings
Press the Menu key.
2. Tap Messaging.
3. Tap Options.
4. Tap Settings.
5. Tap Multimedia message.
6. Tap Access point in use.
7. Tap PAYG MMS
OR1.From the Front Screen press the Menu button.
2.Tap on Settings.
3.Select Applications sett.
4.Select Messaging.
5.Select Multimedia message.
6.Select Access point in use.
7.Select 3MMS.
tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 • Cell Phones
How can i remove the unsent icons in nokia e72?
go to settings under the message menu and chose the delete unsent message.
2helpful
Various times in the day - screen reads service info check, what does this mean?
Nokia 6700 clasic:
Go Menu->Messaging->Message settings->Service messages and choose OFF all three stafs.
Disable= Service messages. message filter. autom. conncetion.
by <dimongrek>
Cant access phone log or messages from main menu. The screen just blinks and stays in main menu. Not receiving messages.
Go to the menu and click on the settings>messages>activate the option called blocked messages.
6helpful
2answers
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
Save Contacts to SIM blind. Nokia Broken Screen
Press Up once - Contact Menu
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
This also maybe useful
Press left once
Press left once
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 • Cell Phones
Cant access memory card messages in nokia 6220
Go to Menu >> Messaging
Press Options (Left Key)
Select Settings
Select "Other"
Under "Memory in use", choose Phone memory or your memory card.
7helpful
2answers
Unwanted calls
You can't prevent anyone from calling or sending texts to your number, but you can easily set your Nokia 1112 to ignore the calls as follows:
Menu -> Settings -> Call Settings -> No. Screening -> Options -> Add
You can also retrieve the number to screen:
Menu -> Call Register -> Received Calls -> Options -> Add to scrn. list.
Calls from screened numbers will not ring on your phone, you will see the number on your screen with a dustbin symbol; messages from screened numbers will go silently to the screened messages folder.
I hope this helps.
Regards,
Rob
Picture messages
Go to Menu>Settings>Restore factory settings
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
