SOURCE: toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
SOURCE: K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
