Tried to save project on disc after saving it with program and these are the errors I received. Failed to launch PowerProducer Project 1) Failed to launch powerproducer project 2) The version does not support this disc utility or function 3) Some video files in the project do not exist
I had the same problem and after troubleshooting found out that the project was not opening because I had changed the location of some pictures I used on a slideshow.
It sucks that the project doesn't have it's own version of the slides and requires the photo files to be in the same physical location as they were when you originally created the slide or used the video file.
Not sure if this will help others, but if you moved any files that you used to create your project, try to restore them to their original location and see that fixes it for you...that fixed my problem.
good luck.
you need to update the program from Summitsoft Logo Design Studio Pro - Macintosh for Mac web sight "suport" here,
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
Exactly the same. File created in Power producer 3NE will not open in same application.
same thing - I have hours on the project so this sucks
Downloaded about 60 digital pictures, worked on them, and saved. Went back a year later and they cannot be found. Found a file with ppp extension, but can not open with program.
Took computer to Data Doctors to see if on hard drive somewhere, but no success.
cannot open the video - i did save it as a power producer icon on desk top but now won't open or burn to disc. All help welcome!!
I WORKED 20+ HOURS ON A VIDEO FOR MY FRIENDS WEDDING, COMPLETED IT OUT, WENT TO BURN AND THE BURNING PROCESS TOOK HOURS, FINALLY I HAD TO CNTL, ALT, DELETE TO MAKE IT STOP, AND END, BUT IT JUST LOCKED UP. I LOST ALL MY TIME AND EFFORT ON THIS PROJECT. NOW I GET THE SAME MESSAGE ABOVE WHEN TRYING TO VIEW IT, I CANNOT EVEN SEE IT. SUCKS REALLY BIG, BECAUSE I WASTED ALLOT OF MY TIME, AND NEVER WAS ABLE TO RECREATE IT. I HATE THIS PROGRAM, NOTHING BUT TROUBLE.
I am getting the same message. I too, have worked hours on a video project only to encounter this.
I have an email in to Cyberlink, and I am awaiting an answer.
Same here. we have all our family home movies in PowerProducer and it gives us the same message. Pure GARBAGE for Software!
I have worked on my baby's video for 20 hours and saved it last night, but when I was trying to open it , the error "failed to lauch powerproducer project " poped up, would be much appreciated if I can get any help on it
[email protected]
I have the same problem...
Did anyone find a solution?
mee three, 12 hours down teh drain, where the F&*) is my project??
I edited 50 video clips into one long clip with some editing. Was able to view once. Then I try to view and get to about 30% and it says failed to launch and gave 3 reasons. the third says some files are missing
