Tried to get it to work but wont. edited profile changed setting cant figure it out please help. trying to set up internet for p168c for t mobile found instructions but they are not working
You have to follow this step by step. if youve tried this and it dont work i have no clue, i have set this up for several people on this site with no problems. as for the comment on uk if you will post this in a seperate help i wil try and help. it is limited to amount of text i can add. i have t mobile and these settings work for me. since you only said internet that is all i am posting.
Data Account Services:
1.) Setting up regular data account services for MMS & T-Zones access.
2.) From the main screen tap the Service icon.
3.) Tap Data account on the Services menu.
4.) Tap GPRS on the Data account menu.
5.) Choose any of the profiles in the current list and tap the button.
6.) You are now on the Edit screen.
7.) Tap the area just below Account name, then tap Edit at the bottom of the screen.
8.) Tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
9.) Tap the area just below APN, then tap the Edit button
10.) Tap in the following text between the quotes
“wap.voicestream.com”
11.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one
and Clear what is in them so they are both blank.
12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
arrows to move the selection so it has Secure, then tap Done.
13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of
the screen. You should now be on the Services menu.
15.) Tap WAP on the Services menu.
16.) Tap Settings on the Internet services menu.
17.) Tap Edit profile on the Settings menu.
18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up
at this time for MMS messaging.
19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
20.) Tap on Profile 8. Tap Edit profile.
21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
22.) Clear the current text, then tap in the following text between the quotes
“T-Zones”
23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen.
24.) Clear the current text except for “HTTP://”, then tap in the following text between the
quotes after the HTTP://
“wap.myvoicestream.com”
25.) Tap the area below Data account, then tap Select at the bottom
of the screen.
26.) Tap GPRS on the Data account menu.
27.) Scroll down the list until you come to T-Mo MMS, the data
account set up earlier under the Data Account Services
section. Tap on T-Mo MMS to select it.
28.) Tap the area below Connection type, then tap Select at the
29.) Tap on HTTP, then tap on OK at the bottom of the screen.
30.) Tap the area below Proxy address, use the numeric keyboard at
the bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050
under Proxy address.
31.) Tap the area below Proxy port, use the numeric keyboard again
to tap in the following numbers “8080” to replace the current 0
value.
32.) Tap the OK button on the bottom of the screen.
33.) The areas under both User name & Password should remain
BLANK. If they are not blank, select each, and Edit them by
clearing all text.
34.) Next tap the Done button at the bottom of the screen.
35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
back to the Select profile screen where a big green check mark will be beside the newly
saved T-Zones profile.
37.) Tap the On/Off button once to exit to the main screen.
38.) If you ONLY want MMS and T-Zones access without the full internet connection,
you can now skip down to the MMS Messaging section and continue setting up MMS
messaging; otherwise continue below at step 39 to set up a second data account service
which will be used for your internet connection.
39.) Setting up a 2nd data account service for full internet access.
40.) Tap the Service icon on the main menu.
41.) Tap Data account on the Services menu.
42.) Tap GPRS on the Data account menu.
43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the
button. The profile right under it would be fine.
44.) You are now on the Edit screen.
45.) Tap the area just below Account name, then tap Edit at the
46.) Tap in the following text between the quotes
“T-Mo Internet”
47.) Tap the area just below APN, then tap the Edit button at the
48.) Tap in the following text between the quotes
“epc.tmobile.com”
49.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one and Clear
50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
52.) Now that you have set up a second account service for internet use we can adjust the
WAP settings for T-Zone to use this faster and less restricted internet gateway.
53.) Tap the On/Off button once to return to the main menu.
54.) Tap the Service icon on the main menu.
55.) Tap WAP on the Services menu.
56.) Tap Settings on the Internet services menu.
57.) Tap Edit profile on the Settings menu.
58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up
at this time for SMS messaging.
59.) Tap T-Zones on the Select profile menu.
60.) Tap Edit profile on the T-Zones menu.
61.) Tap the area below Data account on the Edit profile menu,
then tap the Select button at the bottom of the screen.
62.) Tap GPRS on the Data account menu.
63.) Find and tap on T-Mo Internet on the Data account menu.
64.) Tap the Done button on the bottom of the Edit profile menu.
65.) A Save? question box should pop up. Tap the Yes button at
66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
67.) Tap the On/Off button once to exit to the main screen.
Internet Access:
If all you want to use for internet surfing is the phone’s built-in browser, and you have set up
the data account service for the internet in the earlier setup, then you are ready to surf the
internet by simply tapping on Service from the main menu. Then tapping on WAP and using
the various options to navigate the internet like Homepage, Input address, etc. However, this
won’t provide as robust an internet experience as a Java based internet program such as Opera
Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java
program for browsing the internet, there is one more setting which must be changed prior to
using the Java internet browser.
Java Internet Settings:
1.) From the main menu tap on the Java icon.
2.) Tap Java settings from the Java menu.
3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile,
which ever SIM you are currently setting up.
4.) Use the arrows to scroll the setting until T-Zones appears in the
box.
5.) Tap the OK button at the bottom of the screen.
Now you should be completely set up for internet on the T-Mobile network if you have a T-Mobile internet
plan!
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
lm in england and l use t mobile and vodafone sim cards on my cect p168c but cant receive mms or go on da internet on both of them..could someone help l wud rily appreciate..
thnx
phyl
