Hotpoint HTS16HBR Top Freezer Refrigerator Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No cooling in refrigerator
The freezer is working ok , but there is no cooling in the lower section'
this is a Hotpoint with the freezer on top
  • Captin Dave May 12, 2009
    The fan in the frezer is not running could it be burned up? dose the temp control regulate the fan and could I have a bad temp contrlol?
Anonymous
Level 2:
  • Expert 158 Answers
  • Posted on May 06, 2009
Anonymous
Expert
Level 2:
Answers
158
Questions
0
Helped
102231
Points
418
Air passage from freezer to the lower door maybe blocked with ice build-up
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
323
Points
I had the same problem and after I've cleaned the back fan it worked again
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
1helpful
My fridge is not cooling
My Refrigerator is not cooling. The Freezer works perfectly,but the lower or cooling section stop
working
A loud humming sound is coming from the freezer section. What should I do?
Ice build up hitting the fan???
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8helpful
2answers
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
2helpful
Frig dying?
There is only one cooling unit, airflow dictates percentage split.
Look for airflow blockage in the freezer section.
1helpful
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
1helpful
Freezer leaks into lower section
there is a drain pipe that goes to the bottom of the fridge . push a flexible hose down it to unblock it , it is for the auto defrost .
2helpful
3answers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
