Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gth2548 belt diagram and steering trouble
I need a belt diagram for my husqvarna gth2548, as well as locationof the plate that bolts to underside...also...what is up with the steering?? it barely turns right, yet you can almost do doughnuts when turning left
Anonymous
Level 2:
  • Expert 86 Answers
  • Posted on May 12, 2009
Anonymous
Expert
Level 2:
Answers
86
Questions
0
Helped
90366
Points
216
Go to searsparts.com type in your model number it should show your diagrams and parts for your mower
What causes my Husqvarna LGT 2554 riding mower steering column to drop and disengage? I've replaced a retainer clip which broke again within 2 minutes.
See attached parts diagram.
Check for wear in sector gear (35) and shoulder bolt (58) or loose shoulder bolt. The sector plate should move laterally with little to none horizontally.
Check that washer (13) is in place between the clip and steering support (22). The diagram is somewhat ambiguous but I believe the washer is above the support but not sure. If you didn't have the shaft out then it's likely in the correct position (above or below).
There is also a bushing just below the steering wheel for upper steering support that may also contribute to the problem.
Gth2548 25hp 48" - bolt
Hi hoofprintsfa,
Welcome to fixya!
Here is the website for your manual: www.mymowerparts.com/pdf/Poulan_AYP_1/logt25h48a_e.pdf
Copy and paste this address into your web browser and the manual will be ready to download for you.
Here is a website where you can get parts for your tractor. It includes a parts diagram: http://www.partstree.com/parts/?lc=&mn=Gth2548
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here.....
Thanks,
Handie Andie
Bar bolt on Husqvarna 142e spins.
Go to Searspartsdirect.com and enter the complete Sears model number minus the decimal point. That should bring you to a series of replaceable parts diagrams plus part numbers. If the bolt is not listed as a separate part, then likely it is part of the fuel tank assembly. Hope this helps!
8helpful
2answers
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
1helpful
I broke timing belt when replacing hormonic balancer
Here are some. Hope it helps =D
Timing Marks
Diagram
TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
A/C Compressor Bracket Bolt 37 (50)
Alternator Bracket Adjuster Bolt 16 (22)
Alternator Bracket Bolt 33 (45)
Balance Shaft Pulley Bolt 22 (30)
Camshaft Pulley Bolt
2.2L DOHC 37 (51)
2.2L SOHC & 2.3L 27 (37)
Crankshaft Pulley Bolt 184 (250)
Power Steering Belt Adjuster Nut 11 (15)
Power Steering Pump Bracket Bolt 33 (45)
Power Steering Pump Mounting Bolt 16 (22)
Shift Cable Bracket Bolt 16 (22)
Timing Belt Tension Adjuster 33 (45)
INCH Lbs. (N.m)
Timing Belt Cover Bolt 108 (12)
Valve Cover Nut 90 (10)
Water Pump Bolt 108 (12)
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
