Question about Karcher G 2600 VH Gas Pressure Washer
Pulsating electric pump - Karcher G 2600 VH Gas Pressure Washer
Ryobi 2000PSI Electric Pressure washer
sounds like it is working as it should to me that is why they call it a pressure washer
Mar 19, 2018 | Ryobi Garden
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 | Garden
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
My Hayward pump is pulsating rather than keeping a
make sure all intake unions are tight you have a air leak or top pump seal is bad
Jun 09, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Aug 18, 2009 | Karcher Garden
Pump is pulsating , not pumping full pressure , water supply and screens checked out ok pump model sjv3g627-1 on a briggs 6.5 hp
Pulsating is usually due to a leak. It could be the pump leaking or the hose, gun or wand leaking. Is there water coming out of these anywhere it is not meant to?
It could also be a valve is not closing properly or a seal needs replacing.
Aug 06, 2009 | Garden
Karcher G 2600 VH Gas Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
