Apple iPod touch Logo
Posted on May 06, 2009
Unable to recharge Ipod touch after batery flat less than 10%. please help
Jazz Boyce
Level 1:
  • Contributor 728 Answers
  • Posted on May 06, 2009
Jazz Boyce
Contributor
Level 1:
Answers
728
Questions
Helped
191813
Points
64
You will have to plug the ipod into the computer and let it sit for about ten to fifteen minutes to let it charge up enough past the very low battery level. Then it will connect to itunes and charge normally. When the battery gets that low, it will not act/charge right from a wall or another power outlet.
Anonymous
Level 1:
  • Contributor 45 Answers
Anonymous
Contributor
Level 1:
Answers
45
Questions
0
Helped
31486
Points
89
Have you tried to reset the ipod?
How to enter my password when my screen is black
Try to Restart iPod touch by until Sleep/Wake button until a red slider appears.Next, turn iPod touch on. If iPod touch not responding reset iPod touch, press and hold the Sleep/Wake button and the Home button with same time least 10 seconds, until the Apple logo appears.
If still screen not appear than Recharge iPod touch or try To restore your iPod touch, first make sure you are using the latest version of iTunes(by http://support.apple.com/kb/HT1414). If still not able to solve than take some help with Apple Support Number .
Wont turn on after reset
The iPod Touch has a battery capable of up to 40 hours of audio playback, but depending on how you use your iPod, the battery capacity can vary widely. If you attempt to turn your iPod on and get no result, the battery could be fully drained, which you can easily resolve by connecting it to your computer to recharge it. If this doesn't work, resetting or restoring your iPod may get it working once again.
Charge Connect your iPod Touch to your computer using the USB cable that came with it and charge it for at least 10 minutes before attempting to use it again. If the battery is fully drained, the screen may remain blank for a few minutes after plugging it in, and then a low battery image will appear, indicating that you shouldn't unplug it for at least 10 minutes. Never plug your iPod into your keyboard, but rather into the computer itself. Also make sure your computer is on and not in sleep mode while your iPod is charging, or the battery may drain rather than charge. Reset b> If recharging your iPod doesn't resolve the issue, reset it while it remains connected to your computer. Push the "Sleep/Wake" button and the "Home" button simultaneously until the battery symbol or the Apple logo appears. This takes about 10 seconds. Continue to charge your iPod if the low battery image appears after the reset. Restore b> If your iPod Touch still isn't responding, restore it in recovery mode. First, place your iPod in recovery mode by disconnecting it from the USB cable, and then press and hold the "Home" and "Sleep/Wake" buttons simultaneously until the iPod turns off. Push the "Home" button once again, and continue to hold it while you re-connect your iPod to your computer using the USB cable. Continue holding the "Home" button while the iPod turns on and release it only when the "Connect to iTunes" screen appears. Open iTunes, and click "OK" when the recovery mode alert appears. ITunes will restore your iPod back to factory settings. You'll be able to sync it with iTunes to recover the data you lost during the restore, provided you have synced with iTunes in the recent past. Check Liquid Contact Indicators b> All iPods manufactured since 2006 have built-in liquid contact indicators. If your iPod has been in contact with liquid, this could be the source of your problem. You can check whether the liquid contact indicators have been triggered by looking straight down the headphone jack on your iPod. If you see red or pink at the bottom of the headphone jack, your iPod has been in contact with liquid, and this is likely the cause of its malfunction. Contact an authorized Apple repair center to inquire about whether a repair is possible. Such repairs aren't covered under your iPod's warranty. iPod touch: Hardware troubleshooting http://support.apple.com/kb/ts2771 iOS: Unable to update or restore http://support.apple.com/kb/HT1808
2helpful
Itouch displays "disable connect to iTunes" how can I restore it?
Restart iPod touch
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
If your device does not turn on or displays a red battery icon, try recharging next.
1helpful
My ipod says disabled and try again in 21,345,432 minutes..please help
This explains how to do a hard rest on the IPOD, if you haven't tried it already
To perform an iPod Touch hard reset, start by turning the iPod Touch on. Press and hold down the sleep/wake button until you see the Apple logo on the screen. Next, you need to turn the iPod Touch completely off. Press and hold down the sleep/wake button until you see the red slider. Slide the slider to turn off the iPod Touch. This should fix any potential problems you are having with your iPod Touch.
If you are unable to turn off iPod Touch, you can try doing a manual reset. To do so, hold down the sleep/wake button and home button at the same time. Continue to hold them for at least 10-15 seconds. Wait for the Apple logo to appear.
My ipod wont turn on
Step 1: Try plugging your iPod into your computer for a few minutes. If it begins to charge, let it charge fully.
Step 2: Use your iPod as you normally would. If it needs to recharge very soon, it is a sign that your iPod's battery is dying.
Step 3: You have three choices:
  1. If it is less than a year since you have bought it, go to the Apple Store and they will replace it for free on the spot as part of their 1 year warranty
  2. If it is older, pay them a fee to fix it OR
  3. Bring your iPod with you, and buy a new one for 10% off.
Note: Please vote if you found this to be useful
1helpful
IPod won't Transfer all music
If plugging it into wall charger for 24 doesn't give it enough gump to transfer songs you're gonna need to get a new battery.
2answers
What do you do when an IPOD touch will not recharge?
my suggestion is take ur i pod and place it under the tyer of a jambo truck
IPod Classic won't recharge
This will reset your ipod hopefully it helps
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
  • Not finding what you are looking for?
    Top Apple Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    ZJ Limited
    ZJ Limited
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
