SOURCE: stereo wiring diagram
Here it is! Please rate this info.
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
SOURCE: 2002 Yukon XL with Delco Stereo only has front
sound like the head unit's out put mosfet is going bad, but i have also ran in to this problem when it was a speaker wires shorting out. so first check the connection on your rear speakers.
SOURCE: no sound from speakers
I ran into the same issue... everything was working correctly from the display screen (AM,FM,XM,iPod,Bluetooth) picking up stations, and all controls were working, but no sound at all. I called the dealer and found out there is a reset button that reboots the entire nav/audio system. It is a pin-hole located just to the left of the CD slot on the console. You will need a paper-clip or somthing that size to push it. Hold it in for a few seconds while the system is on and it will shut down and reset. I have to warn you that it does erase almost all of your presets, but did seem to keep my Bluetooth pairings and my nav address book. Good luck!
