Proscan 50" LCD HDTV PLCD5092A - CURTIS INTERNATIONAL LTD Logo
Trisha Dow Posted on Nov 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Proscan 32" LED tv model PLDED3273A-B and my son lost the remote for it. I am trying to program a universal remote but all the codes I have tried won't work. I used the auto program and the remote changed to chanel off the aux channel so now I can't even watch my cabel. At this point I don't even care if I have a remote to the tv, all I want is to get it back to the aux channels to connect to the cabel box. Can someone please help me?
Conn Maney
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 41 Answers
  • Posted on Nov 21, 2013
Conn Maney
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
41
Questions
Helped
9707
Points
51
If you have cable then you should have a remote for the box...use that remote to code in your tv. there should be a list of codes that came with your universal remote and the procedure on how to auto search for the tv code...follow that and you should have it. remember that the tv button only controls the tv,,cable button only controls cable box,,,dvd button only controls dvd player...and so on..
Tony Mitri
Level 2:
Sergeant:
  • Expert 308 Answers
Tony Mitri
Expert
Level 2:
Sergeant:
Answers
308
Questions
0
Helped
77460
Points
693
Proscan Tv codes are 1023,1078, 1081,1098, 1134
One of them will work for sure.
You are welcome!
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
5 Related Answers
Anonymous
  • 1779 Answers
  • Posted on Feb 26, 2009
SOURCE: Unable to get channels after Channel 13.
Go into your menu and make sure the tuner is on Cable, then auto-program....Let me know?
Anonymous
  • Posted on Mar 17, 2009
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Anonymous
  • Posted on Mar 20, 2009
SOURCE: I have tried to program my FiOS Verizon remote
Thank you. I did solve my problem with some diligence. The instructions from Verizon were correct. I realized that there are two buttons on the Verizon universal remote that look alike - the "play" arrow and the "fast forward" double arrow. Once I used both of these buttons in the proper sequence, reprogramming the TV remote with the new code worked.
Anonymous
  • Posted on May 01, 2009
SOURCE: can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
Anonymous
  • 814 Answers
  • Posted on May 21, 2009
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
1helpful
What is the code for this tv?
All In the One Proscan TV Remote control Codes here
2118, 1078, 1107, 1008, 1108, 30000, 2319
My remote control broke, and I bought 2 different universal remotes that will not operate the tv.Do you know why? The model number is PLDED3273A-B
You should set it up with the set-up code to your TV brand; with the codes said to it in the code list of the remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
1helpful
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
Just do a hard reset to this set and check. To make it a hard reset, unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If this do not help you, the main board to your TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
LOST REMOTE FOR PROSCAN 32' LED TV PLDED3273A-B
There a known brand not junk like some of the off brands, A universal remote should work with it , No problem
4helpful
4answers
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
21helpful
11answers
Lcd 32" proscan need code for universal remote
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
