Coffee Makers & Espresso Machines Logo
Joe Sledge Posted on Nov 21, 2013
Adjust thermostat on vaculator coffee maker - Bunn Cuisinart Coffeemaker: Pour-Omatic Coffee Brewer ( O Matic)
2answers
Bunn coffee maker will not quit boiling the water in the tank, what is the solution?
It sounds like the thermostat needs to be change. it is located under the top of the unit. Should be on the left side under the lid. Visit this link to get an idea of the part..http://www.ereplacementparts.com/thermostat-kit-p-847667.html.
My 8572 coffee maker drips hot water ,even when no water is added to the machine.This is making it difficult to know how much water is needed to brew a full pot.
I will assume that it is a pour over brewer from your statement, so the only thing that comes to mind is the thermostat not turning off the elements and the water is boiling and coming out the brew tube. You can try to adjust the thermostat first if that does not help then you might have to replace it.
Hi I have a bunn commercial brewer. its a sh dbc brewer. the brewer keeps heating the water all thw way to 225 degrees and keeps going.
Sounds like the thermostat needs to be replaced adjusted or the probe to the thermostat is covered in scale, and it cannot read the temp correctly. Remove top panel and check probe, if fine no buildup, follow probe line to thermostat and set to a lower setting, if same problem replace thermostat.
Have bunn A-10. want to adjust the temperature hotter. top comes off, cut cannot get next cover off. can you help me locate a thermostat adjuster. reply to [email protected] thanks, john
This illustrated parts catalog should help you with removing the cover.
http://site.bunncoffeemakerparts.com/pdf/A10_pm.pdf
See page 6, item 6 to identify the thermostat assembly.
On page 10, the thermostat knob is identified as item 3.
Use the search function here to locate any parts you might need:
http://www.bunncoffeemakerparts.com/
Adjust temperature higher, HOW?? Problem is reoccurring now every batch brewed.
Could be lime on thermostat probe.When unplugged remove probe and crack off lime deposits.To access ,remove top lid and loosen fill tube nut for fill basin.Take out basin and thermostat is underneath. Also check heating element or hi-limit.Ohm to check with a meter.
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
4helpful
Bunn cwtf15 coffee isn't hot enough the coffee brews @115 degrees
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
1helpful
Water does not heat up have replaced limit thermostat and heating element
Check the other inline fuse on the element to the light, if you get resistance, then the problem is the adjustable thermostat.
How can I adjust my boiler ? the water is only at 140 degres
The thermostat may have gone bad on your espresso machine.
Saeco parts and cleaning supplies:
www.CeriniCoffee.com
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
