ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
Posted on May 05, 2009
Esa 42 in plasma.....out of range?
I have hd service and when i hook up the dvi cable the hd channels come in perfect but the digital or analog channels dont come in the screen says"out of range". so i have to hook up through the s-video and in order to watch non-hd i have to switch the source from dvi to s-video. is there a way i can watch analog through the dvi interface...thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
226
Points
I have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
What is DVI?
VGA cables are the standard way of connecting analog monitors to computers. However, a new standard way had to be developed. Some early standards were proposed but eventually, DVI emerged as the new interface for Digital flat panel LCD monitors and graphics cards. One of the most confusing things about DVI is that there are three different styles of cables and connectors. They are DVI-D: This is the most common style. Almost all DVI-capable devices on the market use a DVI-D interface. DVI-A: In a digital-only world, "DVI Analog" would make no sense. However, as with all new technologies, there needs to be a way to connect to older equipment. DVI-A uses a DVI style connector on a cable that sends an analog-only signal, which can be understood by analog VGA monitors. DVI-I: In practice, DVI Analog-only cables are rare, and DVI Analog devices are non-existent.
The DVI Integrated cables and connectors offer the best of both worlds: a single cable and connector that can transmit both a digital and an analog signal. Since a DVI-I connector offers the most flexibility, video cards such as the ATI Radeon 8500 use this connector so that either a DVI digital screen or VGA monitor can be connected. In DVI an Analog signal will only talk to analog devices, and a Digital signal will only talk to digital devices. Trying to convert a DFP or DVI-D (Digital) signal to a VGA (Analog) signal will never work. Single Link and Dual Link: After all these the difference between DVIs, DVI-D and DVI-I also come in either Single Link or Dual Link. The basic difference is that dual-link can support higher resolutions. Single link cables can be identified as having 8 pins missing, while dual-link cables use 24 pins. Single Link: Can support resolutions up to 1920 x 1080 at 60 Hz. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels a second. Uses 12 of 24 pins. This is more than adequate for most plasma TVs. Dual Link: Can support resolutions up to 2048 x 1536 at 60 Hz. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels a second. Uses all 24 pins. Most DVI digital devices have connectors that can accept dual link cables but there are a few plasma TVs that can only accept a single link cable. So, it's always good to check with your device retailer about the appropriate cable to choose from. Here you will get more information and differences about DVI cables type https://www.404techsupport.com/2014/08/21/dvi-types/ .
I was given norcent 42 in.plasma HD TV model 4201 how come it does not have place to hook cable or antenna and I get into menu and scroll up and down on right side list where factory reset is but cant...
The Norcent PM-4201 plasma doesn't have a TV tuner. It's an ED-ready monitor. You'll need to connect it to a set-top box. This could be a OTA tuner in a computer, DVR OTA tuner, an ATSC converter boxes or a cable/satellite box. According to the specifications here, https://www.cnet.com/products/norcent-pm-4201/specs/ , the PM-4201 does not have any HDMI ports. You'll need a set-top box with composite or component video outputs. With a computer, you can use a DVI output (or HDMI to DVI). Note: the HDMI to DVI connection will not carry audio to the set.
I wish that I had better news for you.
1helpful
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
2answers
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
1helpful
Receiving the sound but no picture on digital TV channels
If you are trying to watch HD TV through the tv and you are only getting sound, it is most likely because you would need an High Definition cable box. Hope it helps
Connect DVD to ESA PDP4294LVI plasma tv
coaxial cables are great for HD boxes and usefull components like that but as for D.V.D... dinosaur feed!
get a converter from "The Source" that will convert coaxial analog to yellow component Video and rca audio. and you will be laughing :)
Trust me i am the flat pannel guru! :)
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Top ESA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
