How to
bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a
Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the
XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password.
First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on.
Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection.
To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again.
Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do.
Besides, you can also take use of Windows password reset CD to remove Windows XP password if you
forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps.
In fact,
Windows Password Unlocker can be used to
bypass windows 7 password,
bypass windows vista password ,
bypass windows NT password and so on.
