Innovage Mini-Digital Camera Logo
Posted on May 05, 2009
Digital camera works, Pc camera shows blank screen(or black screen)
The Camera part works on my Innovage dual mode mini digital keychain camera, but the pc camera mode only leaves a black screen. Sometimes it shows a dark brown fuzzy picture that looks like it wants to show an image. What could this problem be?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
656
Points
Need to know how to use dual mode and need directions for how to use innovage mini digital camera.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
656
Points
How to improve image quality innovage mini digital camera innovage mini digital camera
1helpful
How can i get my images off of my camera if i don't have a cd
You don't need a CD -- You need a computer and a burner
Attach your camera to a computer via a download cable and save them to your hard drive until such a time that you have a CD/DVD burner and a CD or DVD disk then transfer them all to a CD/DVD
J'ai perdu le CD d?installation de INNOVAGE MINI DIGITAL CAMERA
J'ai perdu le CD d'installation de INNOVAGE MINI DIGITAL CAMERA j'aimerai avoir un site de recuperer le software gratuit. Merci
Need software
Below is the link where you can download software for you Keychain mini digital camera.
-http://www.shoptronics.com/midumousbvga.html
Please let me know if you have any further question or concerns.
Thanks.
3helpful
I need a Macbook driver for the Innovage Mini Digital Camera
بدي تعريف تعريف كاميرا SUPP PROFESSIONAL LENS PC CAMERA
it does not work
1helpful
2answers
Lost Cd my mini digital camera
i have the driver, email me @
tech @ lawckedgaming.com
i will send it to your email
2answers
13helpful
23answers
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 • Baby Gear
Top Innovage Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Innovage Camera Expert? Answer questions, earn points and help others
