Sylvania LD370SS8 37 in. LCD Television Logo
A
Anonymous Posted on Nov 20, 2013
Schematic board layout lg
Power drops off
Jennifer Frias
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 21, 2015
Jennifer Frias
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
50
Points
Antenna in coaxal is broke off what to do to fix
1helpful
Need schematics for Peavey max 112 bass amp. Power circuit board has copper traces burned off so a layout of the board traces will do... Thanks for any help
Try to find a new board. Trust me, you are not going to fix it - there is a reason the traces and board are showing burn marks. Either scrap it or just buy another one. If you toss it cut the power cord off next to the chassis.
1helpful
Need schematic power Board LG EAY58316301
Hi Enrique,
Can you provide a model number of your TV to find a service manual and hopefully It will have the schematics for this power supply?
1helpful
Replaced c-board- still no power. can't find a fuse or limit on this model.Is board bad?
did you check the fuse box, are you getting power at the outlet, is there enough power to run the dishwasher.
sometime there is a switch for safety reasons, that switch mite of been the issue all that time, you will need layouts and schematics
Oct 06, 2015 • Dishwashers
1helpful
I have an LG 55lm4700 that has no power led and no picture, wondering what might be the issue.
it sounds like a blown capacitor in the unit somewhere.
here are some tools you are going to have to have: ohm meter,oscilloscope, signal generator, soldering equipment,
grounding equipment, diagrams, schematics, test points, layout of circuits,
How do you fix an LG 50 in Plasma TV with vertical lines?
the vertical stabilizer module circuit burned out.
without schematics ohms meter, oscilloscope, soldering tools,
proper grounds, layout configuration of the circuits configuration, signal generator, you have big project, take it to a professional or repair shop.
Schematic
You have not included necessary info such as brand and model.
You will also never get a 'schematic' for any mother board, only a board layout and specifications since a true schematic would cover an average wall.
Searching for a motherboard wiring diagram on a lg optimus logic
If you are looking for a technical wiring schematic layout on ANY motherboard you aren't going to find it. Those are patented and not released by manufacturers. If you want only the layout of the motherboard, go to the manufacturers website and use their Support section to find yours. OR your computer manufacturer's website may have the manual for your model and that will have a layout diagram.
2helpful
Schematic diagram for power supplys LG 60PC1D-AA
I do not have the schematic, but have a testing / troubleshooting guide for the 60PC1D 1st and 2nd generation, which gives some good insight in organization and functionality of the power boards.
This is what we ourselves step on when repairing - LG often does not publish schematics for power boards and sustain boards.
contact us if interested
6helpful
LG TV (LCD) power supply schematics
Service manual from SAMs does not include a schematic of the power supply board
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
