No sound
So your sound doesn't work for TV now or while watching a movie? Can you try using audio out on TV to connect to other audio source? I wouldn't think that the audio coming in from TV would stop working, but if audio signal works through TV then the speakers are blown, maybe there is a fuse internally that blew, or both speakers blew at the same time, which is more unlikely. If you are comfortable removing cover, do so and check fuses and for other signs of failure like burn spots or melted solder. Please comment on the results. Also, with cover off, speakers can usually be accessed, so try testing them with another audio source. If speakers still work than TV audio is the problem, and could be difficult to replace on your own, but might be worth repairman. Of course, easier solution is to buy cheap receiver and speakers, I can almost gaurantee that would work. But always keep the receipts anyways ;)
hope this helps.
Paul
