My trans is in limp mode & I want to bypass the neutral-safety switch if that can be done, I would like to know how. Can you help?
SOURCE: Need to replace nuetral safety switch on a 1991 Buick Park Avenue
It is located on the transmission follow the gear shift cable to the end on my 1996 nissan sentra it is located on the front righthand side if your looking at the engine (below the battery) it has 3 (10mm) screws to remove and it slips out of the gear shift cable.
SOURCE: park neutral switch is done where are the wires
If you bypass the park/neutral switch, You won't be able to start the engine. You have to repair or replace the switch. Usually on the shift column (whether steering or console) or on the transmission/trans axle..
