In my machine c0202 error code is coming how to solve the problem plz tell me the solution .....
SOURCE: Konica minolta C350 error. C0500,C0200, C0208,C0204,C0202 are coming in my Machine pls Help me
turn off the mine power push the botum uitality with turn on mine power > select turbl rest then off machin and on
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
SOURCE: Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
SOURCE: error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
