Question about KitchenAid KCMS145J Microwave Oven
KCMS145JBL-1 has stopped working no power - KitchenAid KCMS145J Microwave Oven
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: KCMS145JBL-1 stopped heating.
It's likely the magnetron overheated, and when its thermostat tripped, all power was interrupted for safety until it cooled back down.
You likely have a failed magnetron, which is sometimes due to a failed internal cooling fan or clogged filter.
Your owner's manual will help you on locating and checking the filters. Grease filters can be cleaned, but charcoal filters cannot, they must be replaced.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
Sometimes the cooling fan will not run after the cooktop lamps have failed. A surge from the filaments shorting can cause damage to the control circuit board, resulting in odd operation from lights, fan, or turntable.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
Posted on Nov 29, 2009
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
I have microwave oven, PEB2060SM1SS, from GE. it happens twice where no power on display control pannel and oven stop work. The first time, still under warranty, so the guy fix the problem. Then, one year...
go to youtube type in your query and you should see a page go through video's and make note of who posted the video ,so you can keep referring to it . Hope this helps you .
Nov 30, 2010 | General Electric Microwave Oven
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
KCMS145JBL-1 stopped heating. It overheated, shut down, then eventually lights and sensors came back on. Still doesn't heat.
Nov 28, 2009 | KitchenAid KCMS145J Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
37 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
