My router is connected to my laptop but it stopped being connected to my ipad today. I keep getting a note unable to connect to linksys
SOURCE: configure router
You haven't specified the version no of the router. If you would turn the router upside down, you can see the model no and the version no right next to it. Although, the configuration of all the versions would be the same, you still need to make sure it has the latest firmware if its a older version. Here is what we need to do... 1. Connect the modem to the Internet port of the router 2. Connect the desktop to the port 4 of the router 3. With the router turned on, push the reset button on the router and hold it for 20-30 seconds. 4. Power Cycle: Unplug the power from the router and the modem. Wait 30 seconds and turn on the modem first. Wait 1-2 minutes till the ligts on the modem are steady. Turn on the router. 5. Wait till the lights on the router are all turned on (takes around 1 minute) 6. On the desktop, open your web browser 7. In the address bar, type 192.168.1.1 8. It must prompt you for a username and password 9. Skip the username and type the password - 'admin' 10. That must bring up the setup page of the router 11. There is tab on the top right corner - 'Status'. Click on that 12. In the status tab, you must see the internet ip address - 192.168.1.64, which is the ip address provided by the modem 13. Go back to the setup tab 14. In the setup tab, you would see the local ip address = 192.168.1.1 15. Change it to 192.168.2.1 16. Click on Save Settings (scroll down to the lower end of the screen to see this option) 17. Wait for 30 seconds and close the web browser 18. Power Cycle again (refer step 4) 19. Now internet must work on the desktop 20. By default, the network name (SSID) of the linksys router is - 'linksys' 21. You can go to the laptop(i assume it has windows xp), and try to connect to this network by - right click on the wireless icon in the system tray (on the right bottom corner of the screen) and click on 'view available wireless networks' 22. You must see 'linksys' as one of the available wireless networks 23. Try connecting to it and you laptop must work Those steps are generalised and you might get stuck in exceptional cases. If this does not work, please initiate a chat session with any of the experts, if this does not work, because this may require some advanced troubleshooting which would not be possible using those short messages. Good Luck
SOURCE: linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
SOURCE: Laptops stopped connecting wireless
check if you’re computer is properly connected wirelessly to the Linksys router, you will need to perform six steps:
Checking the IP Address of the PC
The IP address of the computer is another indication that the computer is properly connected to the router.
Checking the Wireless Settings on a Linksys Router
The router’s wireless settings should match the wireless settings of the wireless adapter in order for them to communicate.
Disabling Computer Firewall
Make sure that the computer firewall and any third party firewall installed in the computer is disabled. With a firewall enabled on your computer, you may get an invalid IP address. In such cases we have to disable any firewall installed on your PC.
Disabling Proxy Settings
If you have proxy settings, you need to disable these on your computer. If a computer is accompanied by a router, the gateway for the Internet connection, it no longer needs to get any proxy settings to gain access.
NOTE: If you are using Mac to disable the computer's proxy settings.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection.
Pinging the Internet
Ping test helps trace the communication between the computer, the router and the internet. To check the computer’s connection to the Internet you should get valid replies when you perform a ping test
SOURCE: My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
Step 4:
Click OK.
