Question about Polycom SoundPoint IP 501 IP Phone
The phone will not ring and will not call out.
Why does razr goes to voicemail too quick
It could be that the phone is delayed in ringing. Try placing a test call and see how many times it rings in the phone you are calling from before it rings on the phone. Then you can determine if the phone is delayed in ringing. If you hear ringing and the phone rings once and then it goes to voicemail then there may be a setting on your phone that is causing this.
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR MAXX HD
Why does my driod go right to voicemail
Mark
Motorola Support
Jun 01, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
Why won't my phone system ring over the intercom system as it should?
Not sure what you mean by rings over the intercom. Do multiple phones have the lines on them and they all ring or do you put it on night service for the other phones to ring.
May 27, 2014 | NorStar M7310 Corded Phone
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
My ally does not ring
My Dear Please First check the Phone settings in the Ringing Setting IF Your Phone Ringing settings all Ok But Phone in the not Ringing So
Your Phone Ringer Default So Please change Ringer and Ringing Problem will Solved
Oct 24, 2010 | LG Ally Cell Phone
We are unable to turn a ringer on, for when the general number rings, on one Mitel 5020 IP Phone, and we would like to make it so another phone doesn't have to hear the ring on the general number ring.
This is set on the buttons for the phone from within the system programming. Individual buttons can be set to NO Ring, Ring, Ring Continuous, Delay Ring, or Delay Ring Continuous.
Continuous meaning that even if you are on the phone, it will ring audibly on your phone. If it's not set to continuous, it will only give a blip.
You should contact your vendor for assistance in setting this up.
Aug 03, 2010 | Mitel 5220 IP Phone
My new job has a Lucent phone and it does not ring at my desk. The only phone I hear ringing is two doors down from my office. Please help me program my phone to ring at my desk. I all ready tried the...
1.) Are you refering to outside lines ringing?
2.) What if someone dials you on intercom does it ring then?
If #1 the phone SYSTEM usually has an option that you have to program and add you to the ring pool for the outside lines.
If #2 does not ring it is also a function to disallow ring, but it very well could be the phone. Since the line is all that matters and NOT the phone, you could try another phone at your location and see if the same happens. If it does, you will need to program the SYSTEM from either Ext. 10 or 11 to add you to the ring pool and allow ring.
Apr 28, 2010 | Lucent PARTNER18 Corded Phone
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Some phones light up but there is no ringing...
is the ringging assignment setting
means downstair phone been set for incoming ring, so u can see the indicator ligh on and ringging
up stair dint assign a incoming ring so that u only can see the indicator light always blinking w/o ring...
contact yr phone provider to set the ringging assignment
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Need to set ringer on phone to ring in my office
is because the ringging assignment only set to ring at receptionist phone.
u may need contact the phone provider to set the ringging assignment to other for other phone which to ring for incoming call
Jan 14, 2009 | Toshiba DKT-2010 Corded Phone
Polycom SoundPoint IP 501 IP Phone Logo
32 people viewed this question
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
