Watches Logo
Posted on May 05, 2009
Cannot set the date on the casio tachymeter
I purchased a men's steel casio tachymeter watch and cannot set the date. Vey complicated setting date and time
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6528
Points
5
Wen u twist th big thing do it twice and press the top button to set dates
2answers
How do i set my casio giez gs-1001 watch
it is a complicated issue and you need to look at the user manual.
just write the code on the back side and click searched on the URL below which you can also
download a soft version of the user manual .
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
I have a analog /digital watch an the date off set ah i want to set it back
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
I have purchased a PROTREK 3246 i am unable to set my city and latitude longitude the city is srinagar (J & K)
hi nothing of the function is responding in the watch and the word (op en)n in the place of the date
How to set alarm on Casio Mens Wave Ceptor Solar Atomic Ana-Digi Sport Watch - Stainless Steel
If you haven't got instructions, you can get them from the Casio web site.
watches;
Accept terms
1helpful
Casio MDV102 watch - how do you set the date and time
Check out my tips here and find the instructions manual for your watch
The reset tachymeter don't stop at 12 oclock
you should pull the big button fully out, then by pushing the tachymeter play/pause you can set the starting point
wish it's helpful for someone :)
1helpful
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
24helpful
2answers
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
HOW DO i SET THE DATE AND TIME ON A CASIO G - SHOCK WATCH?
pull the trigger up and start seting clock just like the regilar system.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
