Hi. My uncle bought HTC P3300 in Italy and I plugged the adaptor in the another country. The voltage was right... my HTC tuned on for a while. When I noticed that the system was too slow, I turned the unit off and turned it on again. The system hang for a long time and so I decided to do a soft reset by pressing the reset button with the stylus.After doing this the battery indicator light turned off and won't light up again... and worse, I can't turn on my HTC unit! Please help. I don't know what's wrong. Thanks!
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Take ur battery out of the phone..put it back & recharge it with ac adapter for some time (keep it for atleast 6 hrs for full recharge)
Had the same type of problem and called HTC repiar center 1-888-617-1113 and thought it was probly the mother board going bad said it would cost $222 to replace it.
I My HTC 3300 stops after a while. And then doesn't turn on anymore...After several timesI take the battery out...and push the start button it starts again .
The after a while (about 30 minutes) it tops again....
Could anybody tell me that the reason could be and how I could prevent this? or how I could repairit?
My htc p3300 would stop functioning which I purchased at Banglore, India. On pressing the power button it will not "on". When I did soft reset it wouldn "on", and after some time - say 2 hour it will again go "off". This continued for few days. I will recharge my mobile with ac adopter for 2-3 hours. Now the set is not responding on pressing the power button or the soft reset button for the past 3 days. Dont know what to do . Please help.
My phone is dead since last 4 days. Removed the battery.. then inserted it again and connected it to AC adaptor to recharge for 8 hours. It did not work. No amber light, no green light was on as used to be usually. Once I tried to ON but got stuck in the first white screen which also went OFF. Cannot turn ON the set. Please help.
my htc p930 is in a clock work mode recovery and wont turn on what do i do?
