Question about Jura Capresso 26003 Electric Kettle
My Jura Capresso C100 tea kettle #261 does not heat water
On the Capresso tea kettle, the blue light on the control knob should remain on until the required temperature. Instead, the blue light flashes and the water does not heat. The kettle IS properly seated on its base. I use filtered water from my refrigerator dispenser, so sediment is not a problem. Many thanks.
    Top Expert:
  • Jura Capresso Master
  • 54,386 Answers
Defective heating element
Posted on Dec 12, 2017
2 Suggested Answers
6ya staff
SOURCE:
Tom Chichester
  • 54386 Answers
SOURCE: the blue light on my Jura Capresso Kettle blinks when I try to heat water. Nothing happens.
THe heating element may have failed.
Posted on Sep 12, 2012
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
The lights come on but the water does not come out
2 things descale the unit as per user book or make the grind coarser. this is done in or near the coffee beans container. turn the knob in the direction of the larger dot or bean symbols
Feb 25, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
My teakettle is about three months old. I was thrilled with it and told all friends to get one. Suddenly it stopped heating the water. A green light goes on when i push it up to start and thats it. ...
Hi Nancy. There is a fuse or fuse like device in the bottom of your teakettle. There is also a temperature control switch which may be faulty. (if faulty, it is 'open' and the pot thinks the water is hot already) If you have a volt/ohm meter, you can probably find and replace it. You will need the replacement part and tools to install it, including pliers, screw driver and a crimp tool.
since it is three months old, you should consider contacting the manufacturer for relief on this matter.
Good luck on your repair and thanks for visiting FixYa.com today.
Jan 28, 2011 | Jura Capresso H2O Plus 259 Cordless...
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso 26003 Electric Kettle Logo
294 people viewed this question
Top Jura Capresso Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Jura Capresso Kitchen Appliances - Other Expert? Answer questions, earn points and help others
