Your anser should be here
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/chkdsk.mspx?mfr=true
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
View the displayed Command Prompt screen.
If you want CHKDSK to run in read-only mode, type:
CHKDSK c:
If you want CHKDSK to fix errors and not to check bad sectors, type:
CHKDSK c:/f
and press Enter in the Command Prompt.
If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
CHKDSK c:/r or
CHKDSK c:/p and press Enter in the Command Prompt.
Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
