Televison & Video Logo
J
JONALD ZAPATA Posted on Nov 19, 2013
HALF MONITOR BLACK HORIZONTAL - Sanyo Televison & Video
lauwereins
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 21, 2013
lauwereins
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
707
Points
27
The IC horizontal deflection is defect replace TDA3615 or equal
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Thin horizontal black line on lcd monitor
It sounds like the light has gone out at that point on the screen, you're going to have to replace the LCD monitor itself.
Monitor has horizontal lines on half the screen but only sometimes
I would just replace it, the cost to troubleshoot and repair will be more than new.
Lower half portion of the horizontal screen black
hi rafi,
check if problem occurs with another computer, hook up another monitor to your computer to check if your graphic card is making trouble.
if it the monitor, and it still is under warranty and you did not damage it, just return to place of purchase and let the paid pros work their magic1
Good luck
1helpful
2answers
Half of the screen is black - Samsung SynchMaster 710N
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Horizontal line appears even computer is off.
Unfortunately that means your monitor is in need of repair.Most likely you will have to consider replacin the monitor as a 17$ most likely isn't worth the price of repair.
Thanks,
Lee
Marantz plasma monitor half black
It's either gonn'a be one of the horizontal buffer boards going from top 2 bottom that are connected 2 the y-sustainer or the one of the 4 inverters is bad on the y or z board. most likely the y board just check 4 tempeture indifference
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
2answers
Screen
Problem with motherboard display unit.you need to repair the unit.
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
