Question about Hotpoint RVM1325WW Microwave Oven
I have a 2004 HotPoint #REM25SJ01 that has no audio control button. There's no mention of it in the manual either. It's so loud and we can't adjust the volume or mute it. Any ideas?
No audio or mute option on Hotpoint Microwave made in 2004 number REM25SJ01
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
  • 23 Answers
SOURCE: Hotpoint OTR Microwave - Carousel Motor Noise
You should be able to access the turntable motor if you remove the left side filter under the microwave. Disconnect the power, remove the left filter and look up inside that area, the motor may have a cover or plate over it, if so remove it, the motor will be held in with 2 screws (usually) and there will be 2 quick disconnect wires attached to it. If you cannot get to it that way you may have to remove the bottom of the microwave (underneath), should be only 3 to 5 screws holding it in place, the side to the wall will be hinged, once you pull the screws just let it hang or swing down away from you. Then follow the above directions. Make sure that you are getting the correct motor, there are two types, one is a square shaft (WB26X10037) and the other is a "D" shaped shaft (WB26X10038).
Posted on Jan 22, 2008
bestdarngood
  • 3037 Answers
SOURCE: Brand new Hotpoint Microwave doesn't heat
yeah, sounds like the microwave either had a faulty component or a bad connection in the circuitry. Once in a while you will get a bad unit.
Posted on May 26, 2009
  • 82 Answers
SOURCE: hello I have a hotpoint microwave. I just put
need to check the door switches,
Posted on Jul 17, 2009
  • 460 Answers
SOURCE: Microwave is totally dead but has power to it.
the kliestron is most likely bad or the stertup solenoid is stuck. also could be the control module needs replaced...
Posted on Nov 12, 2009
How do you clear a PF on hotpoint microwave oven
The control buttons are likely defective. Is the MW working?
Sep 13, 2016 | Hotpoint Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Nov 08, 2009 | Hotpoint RVM1635 Microwave Oven
Can I lower the volume of my buttons? When you hit the buttons, the sound is really loud. can I control this?
If it has that feature, it would be covered in the owner's manual.
Many GE models do. You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So if you need more free help, please reply back directly to me with your brand and full model number from the tag in or on the unit.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 26, 2009 | Hotpoint RVM1625 Microwave Oven
Hotpoint Over the Range Microwave is LOUD
It is very likely that the motor that spins the plate is wearing out. You can find a replacement on ebay and many other sites.
Jun 06, 2009 | Hotpoint Microwave Ovens
GE Microware Hood SpaceMaker Problem
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | GE JVM1850 1000 Watts Microwave Oven
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Hotpoint RVM1325WW Microwave Oven Logo
49 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
