I'm looking for the code for a Techwood AEDVDRS7 DVD player and a brief explanation on how to set up the remote to the DVD player as it has been some time since i last used it.
User manual for ONE FOR ALL USC3426 lost require code for Baird television
One for all urc-3426 need instructions for its use?>
Contact Axel from universal-fernbedienung.net! He will help you.
Techwood DVD 0713 or 0539
press DVD - Hold MAGIC until LED blinks twice enter number
SOURCE: One For All URC-4640B00 Codes for Sanyo DVD Player
I found a downloadable PDF File of the manual and codes for this remote. Hope it helps.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc4605access4&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4605-manual.zip
SOURCE: access codes for One for all URC4640
SEARCHING FOR YOUR CODE
If your device does not respond to the
remote control after trying all codes
listed for your brand, or if your brand is
not listed at all, try searching for your
code. For example, to search for a code
for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
NOTE: In the search mode, the remote
control will send IR codes from its library
to the selected device, starting with the
most popular code first.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
6. To search for the codes of your other
devices, repeat steps 1 through 5, but
substitute the appropriate device key
for the device you are searching for.
I found this off a urc-4605 manual online but I think it works for all models worked for my urc4640b00
SOURCE: Have a one for all remote urc 3426 but have lost the instruction
http://www.oneforall.com/en_UK/support
This Link Will Sort You Out Hopefully ...Rootsnattyroots
