Kirby Generation 3 Bagged Upright Vacuum Logo
A
Anonymous Posted on Nov 21, 2017
Kirby G5 vaccum cleaner will not turn on
I was vacuuming. There was a spark from the bottom front of the vacuum cleaner and it shut off. The roller belt is good and tight. There are no obstructions preventing the roller from turning. The power light does not come on. The mini emptor "boot" switch is not damaged and is fully engaged. The power cord is brand new.
Thatvacguy.com
Level 3:
  • Kirby Master 1,619 Answers
  • Posted on Nov 22, 2017
Thatvacguy.com
Kirby Master
Level 3:
Answers
1619
Questions
0
Helped
604918
Points
3345
There may be an internal electric problem. It would suggest having it looked at by a qualified technician.
2 Related Answers
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Oct 25, 2007
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Anonymous
  • 715 Answers
  • Posted on Oct 17, 2009
SOURCE: Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
I need a owners manual for a Kirby G5 vacuum cleaner
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
Kirby G5 Owner Manual
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
I have a Kirby G5 Vac Cl, the motor will not run. I checked the ac voltage into the vaccum and is o.k. What is it?
I have the same problem with our G5. I check the cord and it's good. Changed the switch, but that actually wasn't the problem. I've tracked my issue down to the motor brushes. When is does run, sometimes blue sparks are seen on the right-side of the motor near the right set of brushes.
I was able to rotate the motor spindle simply by turning the front attachment belt lever (the thing on the front to take off the vacuum head). This rotates the motor just enough to get better contact with the motor brushes.
I'm next going to replace the brushes and see if that fixes my g5. Good luck.
HOW DO YOU CHANGE THE BELT ON THE G5?
Hi There,
Here's a helpful video that we recorded showing you exactly how to replace the belt on the Kirby Generation vacuums, step by step. This video will also show you how to do the basic maintenance on the roller brush to prolong the life of the belt as long as possible.
If you need to still purchase the belt for your Kirby G5, here's a direct link to our website to the belt that your machine uses:
Kirby G4 & G5 Vacuum Cleaner Belt. Kirby Part # 301291A
Here's the video repair presentation:
Please feel free to ask any follow up questions if you need help, I'm always more then happy to answer any question you may have. If you found this helpful, please be so kind and leave feedback, and / or rate my repair helpful.
This is greatly appreciated, and keeps Fixya experts continue posting free repair advice here on Fixya.
Thanks so much,
Chris Jones
GoVacuum.com
12helpful
How do you replace the belt on my Kirby G5 vacuum cleaner?
Hi There,
We've created a great video demonstration on how to replace the belt on Kirby generation vacuum cleaners. This will walk you through step by step on how you can replace the vacuum's belt, as well as do the basic maintenance on the roller brush to prolong the life of your belt.
I hope that this video helps you! If so, please be sure to rate my repair by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Thanks again,
Chris Jones
GoVacuum.com
5helpful
2answers
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
8helpful
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
1helpful
3answers
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Kirby G5 vacuum
Marci
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
