Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
A
Anonymous Posted on Nov 18, 2013
Where is the serial number of bush tdv6w tumble dryer
1 Related Answer
Anonymous
  • 30 Answers
  • Posted on Aug 27, 2008
SOURCE: Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 • Dryers
1helpful
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 • Dryers
2helpful
3answers
My bush tdv6w vented tumble dryer is not heating up
If your dryer is an electric dryer, it is sounding like you have either a bad heating element or one of the two limit switches are open. The limit switch is an "overtemp" device to shut down the element if it gets too hot from air restriction. Lint build up in the blower and ducting is a major cause of restricted airflow across the heating element. Excessive tripping of the limit will result in an "open" limit switch and continual failure to generate heat. There should be one limit switch built into the heating package and the high limit will be located on the drum usually near the top, though there are some near the bottom of the drum as well. Any attempt to find and replace must be done with the power off as you are dealing with 240 volts.
If your dryer is gas fired, you've had a misfire probably due to a defective hot surface igniter or bad control module. Unless you are fairly capable of learning as you go, and have the basic tools for troubleshooting you probably need to call a sevice technician.
Dec 13, 2014 • Dryers
Where is motor pulley. On bush tdv6w dryer
-It is working why you need to fix...?
Good Luck
mai
Nov 13, 2014 • Dryers
1helpful
Bush tdv6w tumble dryer wont start just flashes lights and beeps
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Nov 25, 2013 • Dryers
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
